pram70
Jul 08, 2021Tutor
Hardwire to router
This is a pre-purchase question. Can I connect the extender directly to the router with an ethernet cable? My ISP"s modem/router is in ther garage. There, I get full speed. In the living room I only ...
- Jul 14, 2021
Glad it worked!
Jul 09, 2021Guru - Experienced User
If you bought the triband and set it up in access point mode, you'd be able to use all 3 bands on the extender.
It'd give you the option of spreading devices out a little more.
Its a solid performing device. Not sure what router you have but it might actually perform better.
