Morgan46
Aug 10, 2020Aspirant
HELP !!!! EX2700 connection issues
Help anyone out there I have x2 EX2700 range extenders and neither will allow me to connect to the internet via them. I have factory reset them and gone through the re-set up process they b...
Morgan46
Ive been using them in the star config the are connected to a Virgin super hub 3, not sure on firm ware as I cannot connect to them, used the wizard to set them up after doing a hard re-set (factory re-set) on them. Went through the process of setting them up then the wizard shut down and they appeared in my network when I checked, you can connect to them but then no acess to the net !!
Aug 10, 2020Guru - Experienced User
try reading through this post
