gryfoxmama
May 20, 2020Aspirant
help choosing wifi extender
Have xfinity with a netgear router. Looking to get wifi boosters. Xfinity says I have to purchase a router from them before they will sell me boosters. Looking to add one basement and also 2nd floo...
May 20, 2020Guru - Experienced User
wifi extenders are great. But I'd only really recommend them if you're only needing 1.
If your home is big enough that you're needing multiple extenders, I'd pay the extra and buy into an actual full mesh system like orbi. Its more stable, has better performance, more options for expanding, and easier with the roaming/single ssid function
- gryfoxmamaMay 20, 2020Aspirant
Only going to be this home another year or so. I will wait till we our in our next home to expand system. Can you recommend just one pod than. Please EASY for me to install. I struggle with all this,
- plemansMay 20, 2020Guru - Experienced User
I'd recommend at minimum a dual band extender.
I'm preferential to the triband extenders because they provide better speeds and coverage. But you can look at the current range of extenders here.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
