rumelk
Feb 14, 2013Aspirant
Help Connect WN802T To BT Business Hub 3.0
Hi
Im trying to do wireless repeating via the BT Business Hub 3.0. I have 3 WN802T and am struggling to even log into the access points.
Can somebody please shed some light on this topic. BT forums are absolutely useless!
Many Thanks
Rumel
Many Thanks
Rumel
1 Reply
- jmizoguchiVirtuoso1. Make sure BT you have support WDS (wireless distribution system) , if not you can not repeat.
2. WNxx should have default IP states in manual. You will need to set the pc with static IP and login the unit
