airforrest
Sep 04, 2019Follower
Help connecting a range extender with a Norton Core router??
I recently purchased a Netgear EX2700 range extender but cant seem to find a way to get it set up with my Norton Core ? It does not have a WPS button, and i've had no luck with Netgear_ext :-(. Does anyone know how to set this up? Cant find any Netgear help phone numbers either !
1 Reply
You can hardwire into the extender and go to mywifiext.net and be able to do setup from there.
If you did want to contact support go to the top and click mynetgear. Register an account and then your device. From there it gives you the options to contact support and use your 90 days of free support.
