cmeach
Nov 18, 2019Follower
Help connecting Netgear universal WiFi Range Extender to new router
Hello! I really hope you can help please. I've been using the Netgear Universal WiFi Range Extender for some 5 years now without any problems. However, I've recently changed Internet prov...
Nov 18, 2019Guru - Experienced User
Easiest, fastest way?
Connect a pc/laptop to the ethernet port on the side of the extender. then try: http://www.mywifiext.net
Include the full http://
Also, if you're doing a reset, make sure to push and hold reset for 7-10 seconds while the device powers up. The lights should change when its been pushed long enough.
