roguesk
Jul 28, 2011Aspirant
Help needed for home setup, regarding access points
Hello guys, in advance thanks for your help and patience. I have taken the time to draw a diagram to help you understand my situations quicker.
Note: The length of the ground floor is probably 60-100 feet. With minimal walls/doors on the ground floor
As it stands I only have the second floor router but due to bad coverage on the ground floor I am planning to place an access point (where indicated).
I have purchased a powerline adapter to minimise cabling for a physical connection to the WAP. This is where I have a few questions that I would appreciate if you could answer.
1. Will the powerline adapter work in this way providing a physical connection to the WAP? Im a believer in wiring and dont like repeating due to complexity and signal deterioration.
In relation to the WAP:
Devices that use wireless are: 3 iphones (wireless n at 2.4ghz) and 2 laptops (wireless g). (future proofing maybe considered)
I am not that fussed with internal network transfer speeds. I am more concerned with range of wireless as internet access everywhere in the house is the priority.
2.Will a wireless N WAP benefit me in this situation or should I stick to the cheaper wireless G WAP's? (future proofing? mainly concerning range?)
3.I require a wired connection from the WAP so that my xbox can be wired to the home network. Is there a WAP that has network switch capabilities or will I need to purchase a seperate network switch to place before the WAP (from powerline adapter)?
4. I would prefer a single SSID where I can switch or the device switches from the upstairs router and WAP when signal is better at a particular point. Is this something that is possible or will I be better off with two seperate SSID's for WAP and wireless router and manually swicth between them?
5. Which WAP do you think would best serve my purpose?
was looking at: netgear wn604?
I apologise if these questions seem obvious, im quite a networking novice so any help would be appreciated. We all started somewhere :D Thank you very much
- jmizoguchiVirtuosoIf you are single story house then use power line or moca ( coac base) devices,
Far as type of wifi router, etc, try to match the best possibility with 802.11 protocol you have on hand,
You can use same SSID, channel and encryption for roaming around the house - rogueskAspirantHello,
sorry for the two topics. I have a 2 storey house like on the diagram. It is a side view of the house.
I have also listed the devices I use with wireless (3 iphones - 2.4Ghz N and latops on G).
Could you please recommend an access point which i can use as a netowrk swicth also. Thank you for your help - rogueskAspirantAnd how do you use same SSID? what settings? I have tried it before and it didnt work. Thank you
- jmizoguchiVirtuosoSSID is the wireless name. Best use same all products so if you have mixed unit, use different SSID
