The1Thinker
Jun 21, 2020Aspirant
Help! Nighthawk X6S AC3000 will not connect to wifi
I have had this problem 2x now. We returned the last extender and got a new one but it is STILL having the issue. I've been on the phone with Netgear and Spectrum multiple times and NO ONE understands...
Jun 21, 2020Guru - Experienced User
Have you tried hardwiring the extender into the modem/router and running it in access point mode to see if it works?
What gateway are you using from spectrum?
Have you tried connecting the EX8000 to a different router and seeing if it works? Maybe it isn't an extender issue.
did you set it up via wps or using the installation wizard?
- The1ThinkerJun 22, 2020AspirantI do think it is something to do with the router. When I searched the specific router (its one of the Wave 2 models), I found 1 forum discussion talking about an issue with the router. Someone said that you can use mac filtering to fix it, but I went through the steps to do that, and still doesnt work. But that definitely feels like the problem.
