burnley22
Jan 03, 2012Aspirant
help wg102 & wgr614 v9 bridging
hi i have a wg102 and want 2 know if I can use it to connect to my xbox via the lan port and connect to my router which is a wgr614 v9 like a bridge if so help would be gr8t thank you
jmizoguchi
Jan 03, 2012Virtuoso
you should able to use repeat. with WEP limited encryption.
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
