bruhtrap
Oct 23, 2021Aspirant
Help with EX3700 setup
Hi, I am experiencing an issue with my EX3700. I accidentally pressed the WPS button and now regardless of what I do it lights up for about 30 seconds and turns off. I cannot currently access my rout...
bruhtrap
In terms of factory reset, I have held it until the power light blinks and then turns amber. I can attempt to do so again.
bruhtrap
So I held the factory reset area until the power LCD turned amber, then flashed green. So far the wps has not lit up at all, while the power is a solid green. How should I proceed from here?
