jpcjguy
Aug 08, 2022Guide
Help with Extender/Router setup
Hi Everyone, So I have the current setup in my house. I use Comcast(Xfinity) as my provider and have a Motorola cable modem. The modem connects to a Netgear AC1750 Smart Wifi Router Model R6400v...
Aug 08, 2022Guru - Experienced User
Let me know how it goes after the reset/reinstall.
jpcjguy
Aug 08, 2022Guide
Plemans,
I did a factory refresh on the router and the extender in the garage. I set the extender up as an access point since it is "hardwired" to the router through a fiber cable underground. I believe that is better than setting it up as a wifi extender.
Everything looks ok. To make sure I understand this correctly - when I am in the house, my laptop connects to the router and displayed as a wireless connection in "attached devices". However, when I take my laptop in the detached garage (and my phone), they should connect to the access point out there since it is a stronger signal. BUT when I am logged into the ROUTER, and look at "attached devices", both the laptop and the phone are showing as "wired" connection, even though they are clearly not. I assume that is because the laptop and the phone, even though wirelessly connected to the access point, "appear" to the router as wired - since their traffic is coming through the fiber cable to the router. I have that correct?
I have not messed with the other extender yet. I moved my Sonos Boost to a hardwired connection on the router, so technically I don't need this extender anymore. Correction - I have an old HP Laserjet 4P printer (circa 1994) that I love that does not have wifi so I have a parallel port print server (StarTech.com PM1115P2) connected to the printer. This was connected to the extender upstairs along with the Sonos. But now I run the ethernet cable right to the printer adapter and bypass the extender.
- plemansAug 09, 2022Guru - Experienced User
You're correct in that if a device is wirelessly connected to the Access Point, it'll show in the primary router as wired. The primary router is only going to display those devices that are connected to it over wireless as a wireless connected device. If you logged into the extender (in ap mode), it'd show the devices are connected wireless. Not a big deal.
Sounds like you got it working well from what I can tell 🙂
- jpcjguyAug 09, 2022Guide
Thanks for the confirmation. It appears that everything is in order at the moment. Thanks!
