amy_9
Jul 28, 2020Initiate
help with wifi extender EX2700
Hello, I originally connected my extender to my home Wifi network (which was not 5G) with no problems. But then I found out that I actually have a 5G network (which I didn't know existed, because I'...
- Jul 29, 2020
The EX2700 is a single band 2.4ghz extender. You won't be able to connect it to 5ghz for this reason.
You'd need to upgrade to a dual band extender to use 5ghz.
Jul 29, 2020Guru - Experienced User
- amy_9Jul 29, 2020Initiate
Thank you so much--that explains it! Really grateful for the help. You've saved me a lot of time.
