brettg2001's avatar
brettg2001
Follower
Oct 14, 2020
Help with WiFi Range Extender WN3000RPv3!
Hello! Can anyone help me out with this issue?
I have a Netgear WiFi range extender WN3000RPv3 and cannot for the life of me connect to mywifiext webpage. I have gone through every single step of the Guided Assistance tool on this help page (https://kb.netgear.com/29746/I-can-t-access-www-mywifiext-net-what-do-I-do). Any suggestions as to what I should do? I have tried several different browsers and several devices. I tried on a Macbook Pro, Ipad, IPhone, and even pulled out my old Windows Asus laptop.
I am still able to connect to the device and use it, but I would really like to be able to check out some of the settings that are accessed through the mywifiext page.
Thank you so much!
1 Reply
  • plemans's avatar
    has it already been setup?
    If so, log into your router and look for the attached devices page or equivelent for your router. It should list the extender and its IP address. try using this ip address to access it.
