Philjer54
Aug 28, 2019Aspirant
HI MY PASSWORD ON MY NETGEAR TILGIN ROUTER WONT CONNECT TO MY NETGEAR AC12 WI FI EXTENDER
Philjer54
Sep 05, 2019Aspirant
Hi again apologies for the vap lock.try again I have model no EX6120 wi fi extender. Trying to connect to netgear tilgin Hg2372 .I have green lights on power.wps.and rueter connection on the extender my problem is trying to connect with my rueter password. It keeps telling me wrong password but I know that it is correct
Best regards Phil McCulloch
Sep 05, 2019Guru - Experienced User
I couldn't find a tilgin hg2372. I could find a hg2380 though. Not sure if the 2372 is the same though. Its not a netgear product.
What firmware is on your extender?
From the sound of it, you're setting it up via the wps method. have you tried hardwiring into the extender and following the manual install guide? Sometimes people have better luck this route.
here's the manual, a basic install guide, and firmware.
