LarryBaxter
May 01, 2020Aspirant
High current draw
My router draws 9 amps at 19 vdc, isn’t that a very high current load??? The unit works fine, but is warm to the touch. Any thoughts?????
May 02, 2020Guru - Experienced User
How are you testing this? Be specific.
the r8000p power supply is only rated to 3.16a with a max output of 60 watt.
If its pulling 9 amps its putting out 171 watts. that power supply should be cooking hot and fried.
LarryBaxter
May 02, 2020Aspirant
I am running off of a 24 volt forklift battery. I am not using the plug in power supply. I am off the grid. I selected the number of power cells that give me 19.4 volts dc. T have a power meter that shows the amperage at 9.2 amps.
- schumakuMay 02, 2020Guru - Experienced User
178.5 Watts? This device must cook and become very hot...
- LarryBaxterMay 02, 2020AspirantThe router is warm, not hot, but it is working
Fine- plemansMay 02, 2020Guru - Experienced UserPower meter running at 3-6v or something? 60 watt is max load. I doubt your maxing out the router
