LarryBaxter
May 01, 2020Aspirant
High current draw
My router draws 9 amps at 19 vdc, isn’t that a very high current load??? The unit works fine, but is warm to the touch. Any thoughts?????
LarryBaxter
May 02, 2020Aspirant
I am running off of a 24 volt forklift battery. I am not using the plug in power supply. I am off the grid. I selected the number of power cells that give me 19.4 volts dc. T have a power meter that shows the amperage at 9.2 amps.
schumaku
May 02, 2020Guru - Experienced User
178.5 Watts? This device must cook and become very hot...
- LarryBaxterMay 02, 2020AspirantThe router is warm, not hot, but it is working
Fine- plemansMay 02, 2020Guru - Experienced UserPower meter running at 3-6v or something? 60 watt is max load. I doubt your maxing out the router
Again, how exactly are you measuring it?
what device?
Or are you measuring it off a solar charger thats direct feeding it?
More details is going to help figure out whats going on.
But the router won't draw more power than it needs. If you're feeding it the proper voltage, its only going to draw the amps it needs.
My bet would be on your device not measuring accurately, measuring wrong, or adding in something else.
