surfmatt
May 21, 2020Aspirant
Home wifi network extenders ex8000
Hi im running a EX8000 NIghthawk x6s mesh extender which ive bonded both the 2G and 5G together and its working fine with my existing Virgin Media Router. The issue is I want to extend the range furt...
- May 21, 2020Orbi is a mesh system. Router and satellites. And you can add satellites as needed to extend coverage. Plus it has the option of a wireless backhaul or wired backhaul.
https://www.netgear.com/orbi/
Again, mesh extenders work great but they work they best if you're only needing 1. when you need more than that, a move to a full mesh system is better.
surfmatt
Thanks plemans - is Orbi a reuter? and are the small socketplug in extenders an option?
cheers Matt
May 21, 2020Guru - Experienced User
- surfmattMay 22, 2020Aspirant
Nice one thank Plemans
