veeja1972
Nov 14, 2013Follower
HomeNet Manager
I have been using this program called HomeNet Manager to run my network. It lets me see all the devices on my network and protect my network from unwanted guests. Anyway I was wondering if anybody knows if this is compatible with the newest Netgear routers? I want to make sure that if I upgrade my hardware this HomeNet Manager product still works. You can find information on the program a this link:
http://www.homenetmanager.com
Any help would be appreciated.
-Anna
-Anna
1 Reply
- jmizoguchiVirtuosoIf you are using other brand router it would not different than any other router brand you would use.
Software likely to be using standard network protocol to scan your network. I don't see any issues when you are going to third part application. I think your question may should be asked at http://www.homenetmanager.com/.
They probably would say it will work fine
