mpgates
Jan 02, 2021Aspirant
HomePod with Model EX7300v2
Apple Product support has stated thtat their HomePod product does not work with the mesh extender Model EX7300v2. Is there any plans to fix this? They recomened Orbi or Eero as solutions. I am usi...
- Jan 03, 2021
Solved it.
I set the extender up as a stand alone circuit, not as a mesh circuit. The Apple HomePod Mini had no problems recogizing the extended circuit. It just had trouble with the "meshed" ciircuit.
Thanks all.
Jan 02, 2021Guru - Experienced User
Apple stated this?
Where?
I don't have that specific extender but I haven't had issues connecting anything to my other extender
- mpgatesJan 02, 2021Aspirant
Thats great. I have not had problems with other devices (iPhone, Honeywell Thermostats, Kuna security lights). But my Homepod Mini can not access the extended mesh cicuit and Apple Support states its a Netgear problem. I can access the un-extended wifi circuit (disconnected extender) with the home pod. So its not an Apple problem and not a Netgear problem, its just my problem.
Apple product supoort advised me over the phone after bumping the question up to a specialist engineer.
plemans wrote:Apple stated this?
Where?
- plemansJan 02, 2021Guru - Experienced User
have you done a quick google search for "homepod wifi issues"
you're not the only one and it isn't isolated to ex7300.
Some found fixes with changing settings. I'd try googling that and reading through a few solutions found with the homepod
Yes, I did a search on both Apple and Netgear and a general search.
Yes, I found a lot of problems out there with HomePod and wifi, but not anything that was similar to my problem.
Remember, my iPhone, my HoneyWell thermostats and my Kuna security cameras all work with my NetGear extender hardware. Apple engineers say it is a problem with the extender, and that only high priced ORBI and ERRO devices work.
