mpgates
Jan 02, 2021Aspirant
HomePod with Model EX7300v2
Apple Product support has stated thtat their HomePod product does not work with the mesh extender Model EX7300v2. Is there any plans to fix this? They recomened Orbi or Eero as solutions. I am usi...
- Jan 03, 2021
Solved it.
I set the extender up as a stand alone circuit, not as a mesh circuit. The Apple HomePod Mini had no problems recogizing the extended circuit. It just had trouble with the "meshed" ciircuit.
Thanks all.
mpgates
Apple product supoort advised me over the phone after bumping the question up to a specialist engineer.
plemans wrote:Apple stated this?
Where?
I don't have that specific extender but I haven't had issues connecting anything to my other extender
Jan 02, 2021Guru - Experienced User
have you done a quick google search for "homepod wifi issues"
you're not the only one and it isn't isolated to ex7300.
Some found fixes with changing settings. I'd try googling that and reading through a few solutions found with the homepod
- mpgatesJan 02, 2021Aspirant
Yes, I did a search on both Apple and Netgear and a general search.
Yes, I found a lot of problems out there with HomePod and wifi, but not anything that was similar to my problem.
Remember, my iPhone, my HoneyWell thermostats and my Kuna security cameras all work with my NetGear extender hardware. Apple engineers say it is a problem with the extender, and that only high priced ORBI and ERRO devices work.
- plemansJan 02, 2021Guru - Experienced User
mpgates wrote:Remember, my iPhone, my HoneyWell thermostats and my Kuna security cameras all work with my NetGear extender hardware. Apple engineers say it is a problem with the extender, and that only high priced ORBI and ERRO devices work.
there should be no reason that it only works with orbi/eero. That'd be a failure on apples part.
- mpgatesJan 03, 2021Aspirant
Solved it.
Thanks all.
