mpgates
Jan 02, 2021Aspirant
HomePod with Model EX7300v2
Apple Product support has stated thtat their HomePod product does not work with the mesh extender Model EX7300v2. Is there any plans to fix this? They recomened Orbi or Eero as solutions. I am usi...
- Jan 03, 2021
Solved it.
I set the extender up as a stand alone circuit, not as a mesh circuit. The Apple HomePod Mini had no problems recogizing the extended circuit. It just had trouble with the "meshed" ciircuit.
Thanks all.
Jan 02, 2021Guru - Experienced User
mpgates wrote:
Remember, my iPhone, my HoneyWell thermostats and my Kuna security cameras all work with my NetGear extender hardware. Apple engineers say it is a problem with the extender, and that only high priced ORBI and ERRO devices work.
there should be no reason that it only works with orbi/eero. That'd be a failure on apples part.
mpgates
Jan 03, 2021Aspirant
Solved it.
Thanks all.
