Rod4823
May 30, 2020Aspirant
Hooking up ps4
Hi i have the AC 1200 A6210 wifi usb adapter trying to use on ps4 wireless ly and cant figure it out
probably because its not compatible.
under "system requirements" for it:
System Requirements
• Intel® Pentium® class PC
• Best performance with USB3.0; compatible
with USB1.1, USB2.0
• Microsoft® Windows® 7, 8, 10, XP, Vista® (32/64-bit)Figured idk how to get a stronger signal
Stronger signal to the ps4?
What router are you using?
Have you tried using a wireless extender?
Or using powerline?
Or using a moca adapter? (ethernet over coax)
