Dalar
Dec 23, 2022Follower
how can I program my WiFi 6 extender without going through the Nighthawk app
Dec 25, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
