Vettewine's avatar
Vettewine
Follower
Jun 21, 2019
How can I setup two EX3700 extenders for the same WI-Fi router?
I have one EX3700 (AC750) WiFi Range Extender that works great for the large-screen TV in my bedroom and I want to extend my WiFi in the opposite direction from my main WiFi router to another large-s...
  • plemans's avatar
    Jun 21, 2019
    You can but I'd make sure that you're using a different ssid for your signals. Also try to seperate your channels to reduce interference.
    Using 1 extender usually works well but when you start adding more than that, its time to possible start looking at systems designed for that like the mesh networks.
