JOJAMACA
Mar 07, 2021Follower
HOW CAN I UPDATE PASSWORD ON AC750 MODEL EX3700
HELLO. I UPDATE MY ROUTER PASSWORD FEW DAYS AGO AND WIFI RAGE EXTENER NO UPDATE. WE FORGOT THE LAST PASSWORD AND NOW WE CAN NOT ACCESS TO WIFI. HOW CAN I UPDATE THE PASSWORD. THENK YOU IN ADVANCE
Mar 08, 2021Guru - Experienced User
1. caps lock. To the left of the "a" key. It helps for reading this.
2. Did you try a simply factory reset on the extender and then install? You can push and hold reset for 7-15 seconds while its powered on. then you should be able to just follow the stock install guide.
