Bravanboy
Dec 05, 2011Novice
How do I access the Menu in a WG602?
I'm using a Netgear RP614 Router connected via Virgin Media Cable Modem and then into the WG602 Access Point. I have a number of devices defined in the WAP from when I had a Windows PC (running XP). I...
jmizoguchi
Dec 11, 2011Virtuoso
if you reset the unit there is default IP of the device
see manual to this model and there is specific on how to access the unit
