Bravanboy
Dec 05, 2011Novice
How do I access the Menu in a WG602?
I'm using a Netgear RP614 Router connected via Virgin Media Cable Modem and then into the WG602 Access Point. I have a number of devices defined in the WAP from when I had a Windows PC (running XP). I...
Bravanboy
Dec 12, 2011Novice
SORTED!
Thanks for the re-direct. I finally managed to find the correct route via the manual. Just needed to put the Static Address into the iMAC before connecting to and logging in to the WAP.
Thanks again.
Cheers!
Thanks again.
Cheers!
