wainfeld
May 08, 2021Follower
How do I add a second mesh extender
How do I add a second Nighthawk X4 mesh extender?
1 Reply
Try powering off the first one that you setup, then add the 2nd one. once its added, try turning the first back on.
I'd advise against daisy chaining them.
Daisy chain: router---->extender----->extender
use them in star configuration
Star: Extender<-------router-------->extender
I also usually advise people to use a full mesh system if you're needing more than 1 extender. they tend to be faster and more stable.
