Thelland7
Apr 03, 2020Follower
How do I change my WiFi name and password on AC750 WiFi range extender
I need to change the Wi-Fi password and also make a change to the SSID. Any advice? Thanks!
Apr 03, 2020Guru - Experienced User
follow what the manual shows. Log into the extender and change the ssid and password?
here's where you can get the manual at
