AniFi
Feb 21, 2020Aspirant
How do I change the connected router?/ Wie ändere ich den verbundenen Router?
### german below ### Hey guys, for a start, I am sorry because I am not really fit in things like this: My original problem was that we had really bad wifi at home. It turned out that there are...
- Feb 26, 2020
Hi AniFi, welcome to the community. We recommend resetting the extender back to factory settings and go through the setup via the installation wizard instead of WPS. During the setup, you can select the option to connect the extender to either the 2.4GHz or 5GHz (or both) signal of the router and select the option to broadcast either the extended 2.4GHz or 5GHz (or both) signal from the extender. The user manual and installation guide are linked below.
http://www.downloads.netgear.com/files/GDC/EX6110/EX6110_QSG_EN.pdf
http://www.downloads.netgear.com/files/GDC/EX6110/EX6110_UM_EN.pdf
Dexter
DexterJB
Feb 26, 2020NETGEAR Moderator
Dexter
- AniFiFeb 27, 2020Aspirant
Thank you very much!
