plageotakes
Sep 21, 2020Follower
How do I connect a wifi extender AC750 to my home network????
I get error messages that I can not reach this pagehow do I correct this. I have Spectrum for my wifi compatable with Netgear?????
Sep 21, 2020Guru - Experienced User
Not sure exactly what you're describing.
Are you stating you can do setup?
Did it setup and your unable to access it?
What exactly is going on? Be detailed since we aren't there to see what you're doing, done, tried.
What firmware is on the extender?
What router are you connecting it to?
Did you do setup using WPS or using the installation assistant?
we need full details to help.
