the1_2many
Jan 11, 2012Novice
How do I connect my WN3000RP to my Sky Broadband NetGear Router
I am having trouble getting my WN3000RP Range Extender to connect to my SkyBroadband NetGear Router. There is no WPS button so that option is no good. I don't have a wireless network manager on my PC ...
tylersmith
Jan 12, 2012Aspirant
You are not alone. I don't have a wps button either. The WN3000RP manual says to "join the NETGEAR_EXT wireless netowrk" without giving the slightest clue as to how one does that. Then, under MANUAL CONNECTION it mentions a "Smart Wizard" without saying how to access that. Then it mentions "www.mywifiext.net". THERE IS NO SUCH SITE! A google search shows others equally puzzled by that.
Can anyone explain how to use this?
