the1_2many
Jan 11, 2012Novice
How do I connect my WN3000RP to my Sky Broadband NetGear Router
I am having trouble getting my WN3000RP Range Extender to connect to my SkyBroadband NetGear Router. There is no WPS button so that option is no good. I don't have a wireless network manager on my PC ...
Baynts
Jan 17, 2012Novice
Hi,
You need some sort of wireless device to connect to the extender in the first instance. For example if you have an iphone or ipad etc search for wifi connections. You will find one called NETEXTENDER_EXT then try and connect to that wifi network the smart wizard will automatically start up.
You cannot connect to www.mywifiext.net from your desktop. That is the address you use once you have connected the wireless device. Once you connect your iphone/pad etc you will be able to browse to www.mywifiext.net from any device that is connected to the extender.
Hope that helps?
Cheers
Hope that helps?
Cheers
