josephwitkin
Jul 13, 2020Tutor
How do I create dedicated backhaul between X6S EX8000 Wireless Extender and Asus triband router?
I am trying to connect my EX8000 wireless extender to my main router, an Asus triband GT-AX11000. The default SSIDs for the two 5 MHz bands on the router are xxxxx-5G for low band, xxxxx-5G-2 for hi ...
Jul 14, 2020Guru - Experienced User
Not 100% on this but the Ex8000 has the 2x 5ghz bands. It prefers to use the wider (1733mbps) for the backhaul versus the other 5ghz channel that is only 866mbps. Reason why is its pointless to have a wide fronthaul if its constricted by the backhaul.
I don't remember off the top of my head which 5ghz is the 1733mbps backhaul that it prefers and I'm not home to hook mine back up.
Does it matter in speed which 5ghz you connect to? If its an issue of which devices you prefer on each band, you could just swap the ssid's around so they auto-swap.
Is it connecting with the wider 5ghz backhaul since I don't remember which one it is?
josephwitkin
Jul 14, 2020Tutor
That’s the problem. The EX8000 is Tri band, and is supposed to connect to the high band for faster backhaul as you say. But there seems to be no way to tell it the SSID of the backhaul band. If I make it the same SSID as the low band it will connect to high band, but so do my other devices. If different SSID, the extender doesn’t see it.
- plemansJul 14, 2020Guru - Experienced User
What firmware is on the extender?
A couple things to try?
1. remove the "-" in the name so name it ****5g2 and not ****5g-2
2. Can you disable the low band 5ghz on the asus just for setup?
Again, not at home right now but I can fire mine back up with my RAX200 and check it.
- josephwitkinJul 14, 2020TutorIt asks for the SSIDs of the bands to extend (but not of the high band for backhaul). I can disable low band but then it will connect to a high channel on my more remote access point, which is a dual band router with many other devices sharing it. If I disable the low band on the router and turn off the access point radio, it will only connect to hi band if has same SSID as the band I am telling it to extend. It seems to need to know the SSID and PW for the backhaul band (makes sense) but there is no way to input that info. If I trick it into connecting to hi band and then go back and change SSID it reconfigures to connect to my access point (which is definitely not stronger. It would need to know the info for the backhaul band in order to connect to it, wouldn’t it?
Firmware is latest. - josephwitkinJul 14, 2020TutorI tried configuring my router and access point (also an ASUS router as AIMesh, which gives everything the same SSID, but lamely, ASUS mesh reserves the hi band for ITS backhaul even though my access point is wired and doesn’t need it- so its not available for the extender
Do you have aimesh enabled?
what firmware is on the Ex8000?
It works with your other router/ap for either high or low band 5ghz?
If so, it makes me a bit suspicious of whatever the asus has setup.
FURRYe38 don't you have an Asus ax11000? Any issues with it connecting to your EX7700 (ex7500, can't remember which triband you have)?
