josephwitkin
Jul 13, 2020Tutor
How do I create dedicated backhaul between X6S EX8000 Wireless Extender and Asus triband router?
I am trying to connect my EX8000 wireless extender to my main router, an Asus triband GT-AX11000. The default SSIDs for the two 5 MHz bands on the router are xxxxx-5G for low band, xxxxx-5G-2 for hi ...
Jul 14, 2020Guru - Experienced User
Do you have aimesh enabled?
what firmware is on the Ex8000?
It works with your other router/ap for either high or low band 5ghz?
If so, it makes me a bit suspicious of whatever the asus has setup.
FURRYe38 don't you have an Asus ax11000? Any issues with it connecting to your EX7700 (ex7500, can't remember which triband you have)?
Something I haven't tried yet. I'll see if I can get some time this week and try out my EX7700 and EX7500 with the AX11000.
- FURRYe38Jul 14, 2020Guru - Experienced User
Heres my EX7500 connected to the GT-AX11000:
- Hardware Version: EX7500
- Firmware Version: V1.0.0.64_1.0.74Connection to Existing Network (2.4GHz)
- Signal Strength: 192 Mbps
- Name (SSID): GTAX
- Connection Status: ConnectedConnection to Existing Network (5GHz)
- Signal Strength: 867 Mbps
- Name (SSID): GTAX
- Connection Status: ConnectedExtender WiFi Status (2.4GHz)
- Name (SSID): GTAX
- Region: North America
- Channel: Auto (5)
- Wireless mode: Up to 400 Mbps
- Wireless AP: On
- Broadcast Name: On
- Wi-Fi Protected Setup: ConfiguredExtender WiFi Status (5GHz)
- Name (SSID): GTAX
- Channel: 149 + 153 + 157(P) + 161
- Wireless mode: Up to 867 Mbps
- Wireless AP: On
I had to update FW from v52 to v64 on the EX7500 to get it to connect finally. IT would not connect using v52.
Asus was factory reset and using default settings from setup wizard with Smart Connect enabled. AX mode was disabled. I went back and re-enabled AX mode on the Asus router and I lost connection to the EX for about 2 minutes. I saw the 5Ghz radio signal on the EX had been lost on its web page while the 2.4Ghz was connected still. I waited and finally got connected with the EX's web page and found the 5Ghz radio was reconncted:
Connection to Existing Network (2.4GHz)- Signal Strength: 192 Mbps
- Name (SSID): GTAX
- Name (SSID): GTAX
- Name (SSID): GTAX
- Channel: Auto (10)
- Wireless AP: On
- Name (SSID): GTAX
- Wireless AP: On
- Wi-Fi Protected Setup: ConfiguredConnection to Existing Network (2.4GHz)
- Name (SSID): GTAX
- Name (SSID): GTAX
- Name (SSID): GTAX
- Wireless AP: On
- Name (SSID): GTAX
- Wireless AP: On
It seems to be working. The front panel 2.4 and 5Ghz LEDS are off. Once I connected my iphone to near the EX, the 5Ghz LED lit up. Once I disconnected the iphone, the LED turned back off.
EX7700 is next...
Here is my EX7700:
- Hardware Version: EX7700
- Firmware Version: V1.0.0.206Connection to Existing Network (2.4GHz)
- Signal Strength: 192Mbps
- Name (SSID): GTAX
- Channel: 4
- Signal Strength: 866Mbps
- Name (SSID): GTAX
- Channel: 161
- Name (SSID): GTAX
- Channel: 4
- Region: United States
- Wireless AP: ON
- Broadcast Name: ON
- WPS: Configured
- Security Type: WPA2-PSK[AES]Extender WiFi Status (5GHz)
- Name (SSID): GTAX
- Channel: 36(p) + 40 + 44 + 48
- Wireless mode: Up to 866.7 Mbps
- Wireless AP: ON
- WPS: Configured
Same configuration with Asus router. I disabled AX mode first. The EX connected. Then re-enabled AX mode and the EX kept the connection. iPhone connected. Saw front panel LED turn on. Front panel LED turned back off after I disconnected the iPhone.
- josephwitkinJul 14, 2020Tutor
Thank you for your detailed info!
Interesting - on my Status page, it shows the channels that the Extender is using to connect to the router - in my case channel 161, a high band channel, but on my wired Access Point (I can tell by the channel numbers reported on the routers' interfaces), not the GT-AX11000.Since the "connection to existing network" is supposed to be dedicated and exclusive, I am wondering if your backhaul is low band- 867 MBps is the upper limit for low band, while for high band it can be 1700-something. Since your high band channels are available under extender wi-fi. The backhaul is supposed to be exclusive.
I also have Smart Connect enabled, so all the SSIDs are the same now. I have AX on, but tried it before with AX off and didn't make a difference.
I guess 7500 and 8000 firmware versions are different. Netgear website lists current firmware as 1.0.1.202, but my EX8000 upgraded itself to 206 a while back. It now says its the latest when I check through the device.
Here is my status data- Hardware Version: EX8000
- Firmware Version: V1.0.1.206Connection to Existing Network (2.4GHz)
- Name (SSID): macnet1
- Channel: 6
- Signal Strength: 1053Mbps
- Channel: 161
- EXTENDER WiFi Status 2.4 GHz
- Channel: 6
- Wireless AP: ON
- EXTENDER WiFi Status 5 GHz
- Channel: 36 + 40 + 44(p) + 48
- Wireless AP: ON
- WPS: Configured
Come to think of it - thinking out loud -
Triband device divides high and low 5 MHz channels into two separate networks with separate throughput and bandwidth.
A dual access device has all of the 5 MHz channels under one network - but its the same range of channels.
So if the triband router's hi band is dedicated as backhaul for an extender connection (what I'm trying to acheive) - but my wired access point (third device) is dual band and will offer ALL the 5MHz channels, including the router's "dedicated" channel - can the backhaul ever actually be dedicated?
In other words, if the EX8000 backhaul to the router is on hi band ch 157, and other devices connect to my wired access poinr on the same channel (can anything prevent that?) , is the backhaul still dedicated? I guess it is on a different radio..trying to grasp...
