josephwitkin
Jul 13, 2020Tutor
How do I create dedicated backhaul between X6S EX8000 Wireless Extender and Asus triband router?
I am trying to connect my EX8000 wireless extender to my main router, an Asus triband GT-AX11000. The default SSIDs for the two 5 MHz bands on the router are xxxxx-5G for low band, xxxxx-5G-2 for hi ...
josephwitkin
Jul 14, 2020Tutor
Yes, it makes sense that Asus AiMesh would operate that way - but if that is the case, it should provide a way for 3rd party devices that want to use the backhaul the same way to use it. The Netgear EX8000 extender does not show up as a potential Asus Mesh node if I search for nodes. I guess Asus AI Mesh is Asus only. I've pretty much given up on that.
But using my setup without Mesh - just Asus router, Asus wired access point, and Netgear EX8000 extender - should work, and is working. I'm just trying to figure out how to make the extender's backhaul band dedicated, with no other devices on it.
Jul 15, 2020Guru - Experienced User
Probably something that may not be compatible. Something to ask ASUS about to see if it maybe possible with there HW. OF course, some mfrs only allow compatibiity with in there own domain so something to keep in mind.
Good Luck.
