helpmeNetgear
May 06, 2013Tutor
How do I remove or block this device from getting my wireless connection signal
hi I have an N600 Wireless Dual Band Router WNDR3400v2 and I'm looking at my Net Gear genie an device that is not my own I don't even recognize it and its getting my network connection how do I block ...
jmizoguchi
May 07, 2013Virtuoso
You will need to use WPA2 encryption and disable WPS
MAC Filter by itself by no means of security at all. This feature is to control the devices which has access to network but if you have weak encryption someone can HACK the encryption and SPOOF the mac address
