Burdell
Mar 31, 2021Tutor
How do I set up my EX 5000 Extender when the enclosed instructions are useless??
Just got an EX5000 Extender to connect to my Netgear Router and the instructions on how to connect it are effing useless. The wesite that Im instructed to go to in order to register and set up a pas...
Mar 31, 2021Guru - Experienced User
This youtube goes over using the installation assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
here's where you can get the guide and manuals.
https://www.netgear.com/support/product/ex5000
where is it failing in the process?
What router are you connecting it to?
Burdell
Apr 01, 2021Tutor
Thanks Plemans! That worked..Extender is connected with all lights on. Wish I could say it has made a big difference but my wi fi is still poor. I may be in a 'bad' area that Im just going to have to live with
