Ibaroj's avatar
Ibaroj
Tutor
Jun 13, 2022
How do I turn off client wifi on EX8000 range extender?
In other words, I just need the extender to wirelessly connect to my primary router's wifi and provide wired ethernet connections only. i.e., a client bridge. I do not see a way to use the extender w...
  • plemans's avatar
    Jun 17, 2022
    Well it still needs to use the signal to connect back.
    And it doesn't have a "bridge" mode.
    so you're a little stuck.
    If users are connecting to it, simply change its broadcast ssid/password so it doesn't.
