Ibaroj
Jun 13, 2022Tutor
How do I turn off client wifi on EX8000 range extender?
In other words, I just need the extender to wirelessly connect to my primary router's wifi and provide wired ethernet connections only. i.e., a client bridge. I do not see a way to use the extender w...
- Jun 17, 2022
Well it still needs to use the signal to connect back.
And it doesn't have a "bridge" mode.
so you're a little stuck.
If users are connecting to it, simply change its broadcast ssid/password so it doesn't.
Jun 17, 2022Guru - Experienced User
Ibaroj
Jun 17, 2022Tutor
The question was posted before it was known that the device can be used in a mesh with a single SSID. Device was donated.
