atcdav
Feb 27, 2014Aspirant
How do I update my router in AP mode?
I have a WNDR3400 I am using as an Access Point. I see there is newer firmware available. When I log into the unit is says no internet connection. It is working properly as Access Point and it is actu...
Retired_Member
Feb 27, 2014Download from support, log it to AP, updates, browse to location you saved FW
Since you had to ask you should think twice about doing this because it is working and may cause more grief than it's worth, since you're using it as AP.
