J_loonam
Jul 04, 2023Aspirant
How do you upload firmware to an extender if you can’t get it to connect to your wifi?
EX6150-100nas using apple computers. I don’t know what the router is; it’s my parents’. We tried adding an extender with the Nighthawk app and it was a flipping disaster. Two of us tried; it just ...
schumaku
Jul 07, 2023Guru - Experienced User
J_loonam wrote:
EX6150-100nas
We tried adding an extender with the Nighthawk app and it was a flipping disaster. Two of us tried; it just took us in circles and wouldn’t connect.
I then tried the WPA button (WHY doesn’t Netgear say to use this??),
but I’m not sure it’s connected to the system. There’s no second network listed in local networks, and the signal is no better.
They certainly told you. 8-)
A good start would be having an eye on the fine NETGEAR AC1200 WiF Range Extender Model EX6150 User Manual. In the Get Started section, starting from p.9 ff. Not far away, in the Install the WiFi Extender section, ...
Place the Extender and Apply Power
Connect to an Existing WiFi Network
Connect with WPS
A great trouble description, isn't it? No idea on what to say....
Connect with WPS
Consult the extender Status Screen Display. This adventure does begin on Log In to the Extender After Installation:
To answer the initial subject question; The Firmware Update process is on p.42 ff.
jloonam
Jul 08, 2023Aspirant
There was no manual in the box, only a quick start guide. It did not tell us to use the WPS button, only the Nighthawk app. After an hour with customer support,we could not get them working so returned. Unusual for Netgear hardware.
- schumakuJul 08, 2023Guru - Experienced User
This is about the standard for many years. However, the information ref, the User Manual is there - just the complete QSG of the v1 hardware is much to long, so it's hard to find.
I'm a little bit disappointed the Helpdesk (paid work, by Netgear) was not able to assist you further. Almost everything I could think about required is in the fine UM.
- jloonamJul 08, 2023Aspirant
Yes, it’s the standard, but I’ve also found it standard for the “quick start guide” to guide you through the quickest way. Therefore, I did not look for the manual off the bat.
