edrizz
Apr 08, 2020Tutor
How enable Seamless Roaming? - EX6100v2
I just purchased an EX6100v2 extender. Says it supports "Seamless Roaming with One WiFi Name". Just trying to find out how to enable this feature and if there are any special requirements (certain r...
- Apr 09, 2020
Even though when I ran firmware check it said I had the latest version, I went to the product page and downloaded the V1.0.1.86 version. Once installed, I now get the "enable one wifi name" option in the set-up. Thanks!
Apr 09, 2020Guru - Experienced User
The EX6100v2 just got the mesh option on the latest firmware upgrade 1.0.1.86
What version are you on?
It doesn't look like the guides have been updated.
And seamless roaming is a bit of stretch. It allows the device's (phone, tablet, etc) own roaming spec's to control when it switches from router to extender. There isn't an integrated controller running it.
edrizz
Apr 09, 2020Tutor
Thanks for the reply. It says I have firmware version V1.0.1.76 but when I select update firmware it says that I have the latest version.
- edrizzApr 09, 2020Tutor
- plemansApr 10, 2020Guru - Experienced User
Glad to hear you go it up and running!
Sad that support didn't know to check to see if you were on the firmware supporting mesh function
