edrizz
Apr 08, 2020Tutor
How enable Seamless Roaming? - EX6100v2
I just purchased an EX6100v2 extender. Says it supports "Seamless Roaming with One WiFi Name". Just trying to find out how to enable this feature and if there are any special requirements (certain r...
- Apr 09, 2020
Even though when I ran firmware check it said I had the latest version, I went to the product page and downloaded the V1.0.1.86 version. Once installed, I now get the "enable one wifi name" option in the set-up. Thanks!
edrizz
Apr 09, 2020Tutor
Thanks for the reply. It says I have firmware version V1.0.1.76 but when I select update firmware it says that I have the latest version.
edrizz
Apr 09, 2020Tutor
- plemansApr 10, 2020Guru - Experienced User
Glad to hear you go it up and running!
Sad that support didn't know to check to see if you were on the firmware supporting mesh function
