BillS22
Dec 11, 2011Star
How I configured my WN3000RP
AT first I had many of the same problems: Dropped Network Device Lockups Then it dawned on me that I might have a Network Overlap Issue. I have a NETGEAR Wireless Router, but it's in the far c...
jmizoguchi
Dec 11, 2011Virtuoso
I found that if some devices used the Router's SSID while other Devices used the WN3000RP's SSID, the Network would lock up.
But when I made sure all wireless devices used the WN3000RP's SSID only, the lock up's went away.
so you have like this
wireless router.... ssid name : xxx
extender has xxx_ext
Different SSID name. So when you say lock up, how do you define that since you can connect extender despite some WPS issues
