BillS22
Dec 11, 2011Star
How I configured my WN3000RP
AT first I had many of the same problems: Dropped Network Device Lockups Then it dawned on me that I might have a Network Overlap Issue. I have a NETGEAR Wireless Router, but it's in the far c...
GReid
Dec 17, 2011Aspirant
let wrote: What if you need the coverage of both your router AND access point?
Could you simply give the access point the same SSID as the router?
I lose wireless on the access point after a day or so, yet the router wireless is still OK. Been a bear trying to figure out why.
For what it's worth. I left my main computer, the one next to the router on the router part of the network.
My daughters bedroom is also close to that computer, so it is set up to work with the router.
My living room, where 2 laptops, and the Blu-Ray reside are on the WN3000RP. Since the Master Bedroom and Living Room are the furthest away from the router, they are only configured for the WN3000RP.
I have had the system up like this for several days now, without any problems.
