BillS22
Dec 11, 2011Star
How I configured my WN3000RP
AT first I had many of the same problems: Dropped Network Device Lockups Then it dawned on me that I might have a Network Overlap Issue. I have a NETGEAR Wireless Router, but it's in the far c...
Max07
Dec 17, 2011Aspirant
GReid wrote: JFOX and BillS
I want to thank you for your instructions that you posted.
I spent the entire day yesterday trying to get my WN3000RP configured on my wireless network.
After reading your posts, I started again, using your instructions.
I was able to get all my laptop computers, Wii and Sony Blu-Ray with Netflix up and operational using the extender in very short order.
Now, I have internet access from the far end of the house using my I-Pad2.
I, like many, have been frustrated with little or no access when you get to far from the main router.
Good Job Grasshopper!! You done good!
OK, this was VERY helpful, and got me further than following either the "in the box" or the online directions (which conflict, by the way). However, I can't get my laptop to connect to the extender, sitting right next to it. I can still connect to the router, but the extender is telling me the security key is wrong, even though I copied it directly from the setup.
Any thoughts? Thanks in advance!
