wifi_surfer
Aug 12, 2012Aspirant
how I just recovered my WN802T-200 from bricked status
the following information is purely a recollection of what I have had to do in the last 24 hours to get my WN802T-200 apparently working again. No warranty, liability or support expectation of any ki...
wifi_surfer
Oct 13, 2012Aspirant
I didn’t make any specific changes to putty other than choosing ‘com3’ and setting the speed and settings for com3.
com3 was the com port allocated under windows 7 when I plugged the usb cable in.
On my pc the defaults for window, translation, remote character set is ‘ISO-8859-1:1998 (Latin-1, West Europe)’. Yours too ?
Some thoughts:
- I am using windows 7 64 bit ultimate.
- I’m in the United Kingdom, my settings are for UK English, etc.
- Are you sure your cable is serial ttl (3.3v) ?
- Is there any risk of electrical noise upsetting your connection?
Hope that helps.
Some thoughts:
Hope that helps.
