Ultrabikeman
Jun 29, 2024Follower
How to change a device connection speed from 5G to 2.4G
MR60 Mesh Router and MS60 Extender: Can a connected device be assigned from 5G to 2.4G connection speed? My Amazon Echos all need to be assigned to 2.4. If so, how is this done?
- Jun 29, 2024
You'd have to separate the bands to do so.
Can I create separate 2.4GHz and 5GHz SSIDs on my Nighthawk Mesh WiFi 6 products? - NETGEAR Support
otherwise its based on your devices own roaming protocols.
Jun 29, 2024Guru - Experienced User
