lalamoe
Jul 11, 2011Aspirant
How to change IP Address back?
Hello, you can probably tell I am a newbie here and my knowledge with routers and whatnot is very small :( Which would explain why I made this big mistake and now I want to reverse what I did. A few ...
jmizoguchi
Jul 12, 2011Virtuoso
http://www.cisco.com/web/consumer/support/userguides2/4005527.pdf
okay this basic modem only ...
follow exactly...:)
you can not skip any of it. also you may want to turn off the cable modem for 20min or so
I clicked on your "Router Reset", and I went to the No.4 instructions, but I don't know If I either have to follow Step 1 and then Step 5, or I can only do one of them?
follow exactly...:)
